hey guys, just wondering my stock rear coolant line where the coolant goes behind the engine bay firewall.. was just wondering.. could i chop it a little bit and then put a rubber pipe in the middle so i can extend it a little bit? would this be ok? Tao from hypgear said it would be ok but i was just making sure if it would be ok?
heres a picture as well... its near the manifold...
Edited by geraus
Na Stao(hypergear) i took off my turbo and brang it to his workshop yesterday to put in a .63 rear housing and behindg it , it is pushing the rear banjo coolant a bit back so i need to moditfy it a little bit to fit, Unless would you guys know any shops that would sell braided ones? hmm
Heres a pic of the banjob hose bolt i grinded off and hers the pic of the new hypergear .63 rear housing
Edited by geraus
Do you guys think the FUEL line would be ok to use as the coolant line for the turbo?? heres are some pics... just to make sure if its ok? im scared the line will melt or something?
Edited by geraus
Yeh im running no heatshield. I went into autobarn and asked them for any type of pipe but they had none! :D the guys like im not sure buddy. so yeh would you guys know any places where i can get a good pipe? im worried this fuel pipe would burst? it looks strong though... like it saids "made in USA" lolll. What are your opinoins on this fuel line for hot coolant coming in?
Im not sure if its the hot coolant that you need to be worried about :) Its the heat from the exhaust housing thats going to cause you problems.
I dont see why you couldnt take the turbo in to a shop and get them to make up a new braided line for it? Better be safe than sorry right? Cos where that line is, you might not even realise its burst/melted while driving, and then your turbo doenst have cooling... you know where im going....
Oh right.
Umm, i would have thought any performance shop could probly make something up for you? Personally i have never had lines made either so wouldnt know where to start looking :) But theres hundreds of custom cars on here, someone must be able to help.. R31??
Yeh hmm, It doesnt matter now at the moment but thanks for your help brother, I already made one up i'l see how i go from there... I used a rubber fuel line and bent the stock line not near the manifold. Hopefully it should be ok. i'l also wrap some exhaust wrap around it or something.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
