Eoi: Apexi Ax53b70 Kit, Moonface Mf-r Dump, Sard Torque Control Valve, Z32, Ats Carbonetic 2 Way Lsd, Full R33 Gtr Interior, Bilsteins, Tomei, Pfc
Well im sick of renting and I have seen a house I would like to purchase so it maybe time to strip my R33. Yes I have only just finished it and have spent an absolute fortune building it using the best parts available but if there is enough interest in the following parts I will strip it all down with most parts removable the day a buyer wants them.
Location - Adelaide can post/courier at buyers expense
Contact - PM or SMS 0404998591
Apexi AX53B70 Turbine Kit - equivalent of HKS GT-RS but in some people opinion better as its more responsive and punchy on a RB25 they make a very responsive 250rwkw on 14psi and up to 322rwkw on a built 25 with 22psi. The turbo is a complete kit including braided lines, fittings, elbow etc. Price - $1650
Apexi Power FC complete with hand controller in excellent condition complete with purchase receipt. Currently has an excellent map for the stock turbo with FMIC, 3" exhaust etc. Price - $1400
PFC Datalogit interface complete with software, USB adaptor etc. This is the latest version that will work on any Power FC. Price - $475
Apexi Super Suction Metal Intake Pipe to suit RB in excellent condition complete with silicon joiners. Price - $225
Moonface MF-R Stainless Dump and Front Pipe to suit R32 R33 Stagea. Unique and extremely high flowing dump/front setup with excellent ground clearance due to design and distinctive engine note. Bought new and used for a few dyno runs on my just finished car still comes with the original Moonface gaskets and bolt kit + stickers. These are rare to find here in Oz and are $907 from Nengun at the moment http://www.nengun.com/moonface/exhaust-chamber-pro Price - $550
Sard Torque Control Valve - replaces your cat and gives excellent improvements in down low torque and also seems to decrease lag. Similar to the down low torquey feeling when you put a silencer in your cannon but with a silencer you have no power up top. With the SARD valve you have heaps of power all the way through the rev range. Price - $300
Z32 AFM complete with plug in excellent condition was bought new and barely used since - Price - $250
ATS Carbonetics 2 Way LSD 4.3 Ratio in S14/R33/R34 five bolt half shaft housing. The diff is in excellent condition and has barely seen much use since purchase with fresh oil. These diff centres are one of the best money can buy perfectly streetable with excellent traction. Price - $1000
Tomei HICAS Lock Kit to suit HICAS vehicles. The kit is used but still in good condition and easy to install. Price - $120
Full R33 GTR Interior in excellent condition including front and rear seats + front and rear door trims/cards. Price - $1400
R33 GTS-T Whiteline Handling kit including valved Bilstein Shocks, Whiteline Springs, Adjustable Front and Rear Swaybars, Castor Rods with Castor Adjustable Bushes. Price - $1500
R33 GTS-T Ohlins Rear Damper Adjustable Shocks and Springs. These shocks feature massive inverse monotube inserts. Price - $450 Pair
R33 GTS-T Series 2 UAS Carbon Fibre Vented Bonnet complete with Sparco Racing bonnet pins. Price - $600
R33 Custom Catch Can setup mounts on the drivers side strut toward and sits between plenum and fuse box. Features speedflow fittings, speedflow lines and a K&N Filter. Easy to fit comes with speedflow fittings for your rocker covers to replace the stock fittings. Installation takes 5 mins looks awesome and cost over $300 to have custom made. Price - $200
Genuine Rear Strut Brace to suit R33 in excellent condition. Price - $150
Brand New DBA 4000 Slotted Rear Rotors model 4908SL/R to suit R33 GTS-t, R34 GT-T, R32 GTR + others. Price - $280
Front R34 GT-T Slotted Front Rotors used very low kms but in excellent condition and freshly machined.Price - $200
R33 Genuine Ganador Mirrors painted black ready to fit, you can paint any colour to suit your car - $450
Cusco Front Camber Adjustable Upper Arms suit R33 R34 Stagea barely used in excellent condition. Price - $425
Cusco Rear Camber Adjustable Upper Arms suit R33 S14 in excellent condition - Price - $280
Nardi Steering wheel in excellent condition complete with boss kit to suit R33 - Price $200
Greddy Oil Cooler kit to suit R33 GTS-t would suit most RB's with just modifying core mounting brackets. The kit is new and has only been trial fitted will comes with original box, instructions etc etc. Price - $600
HKS EIDS Idle Stabilizer unit brand new in box perfect for stopping that stalling when you come off the loud pedal hard or smoothing out your idle - Price $100
GFB Stealth FX BOV kit complete with trumpet and normal BOV adaptors. Currently has the universal adaptor fitted also have a S15 adaptor kit I can supply with it for free Price - $300
R33 Series 2 Front Bar in black complete with the rare Nismo Lower Lip. Price - $400
R34 GT-T Stockies complete with new 225/45/17 rubber and all centre caps. Price - $500
Brand New Bodyform 400R Rear Bar and Side Skirts these people make the best fitting and highest quality kits hand made in Australia. Cost $950 + postage with receipt of purchase. Price - $800
Brand New R33 PSI Parts Du-Luck Rear Bar and Side Skirts cost $846 with receipt of purchase. Price - $400
Edited by nigelswazi
keen if u able to split front + rear swaybars.
cheers.
Prefer to sell handling kit as a kit at this stage as its all designed to work together but if I were to seperate the swaybars would be sold as a pair only.
As asked in PM's the Apexi Kit is a low mount kit to which you can still fit the stock heat shield for stealth mounting. The turbo also features an adjustable actuator.
Hey mate, would you consider selling the 4 Bilstein shocks separately? What sort of $ would you take?
Also interested in the HICAS lock kit- does it include the module to intercept the HICAS computer?
Cheers
Edited by Yeedogga
What color is the stealth BOV and will the OLINS rears fit an R34GT-t ? and what spring rate ? :D
Edited by BASHO
Cheers
Not really wanting to seperate the kit to be honest already had people interested in the whole lot
The HICAS Lock Kit includes the special shims and the module to intercept the HICAS computer
The Stealth BOV has a silver body. The Ohlins will only fit S14/S15 and R33 GTS-t the R34 has a saddle type fitment at the bottom.
pics of catch plz mate
Will take some tomorrow of it fitted before I remove it
whats your absolute best price on the turbo???
Plenty of PM's regarding the turbo so the price I SMS'd you yesterday would be the best price champ
hi mate
just in case u change ur mind, i'll take ur front and rear swaybar since @yeedogga also interested in the suspension set. maybe we can work something.
cheers.
hi mate
cheers.
Not really that keen to seperate due to the extra hassle of three lots of payment and posting but if I was to seperate would seperate as follows:
$1100 Bilsteins + Shocks
$375 Swaybars
$125 Adj Castor Rods
what housing is the apexi turbo it should have a few more letter like p20 or p25 etc at the end.
i had the p20 on my s14 and it made 260kw but if u have the bigger housing i wouldnt mine it for my 34 could u please find out for me dude
cheers
julz
cheers
julz
Hi Julz,
This has the P25 housing and on the box it specifies its made for a RB25 so perfectly matched to all RB25 setups
i sent you pm
PM Replied sorry about delay have been swamped with PM's and busy removing parts for buyers
The Apexi Turbo Kit is SOLD PENDING PAYMENT
ATS Carbonetic 2 Way LSD SOLD PENDING PAYMENT
The HKS EIDS, Z32 AFM and the Apexi Suction Kit are now confirmed sold and on their way to their respective new owners
Just to update the following is still for sale
R33 UAS Carbon Fibre Vented Bonnet complete with Sparco Racing bonnet pins. Price - $600
Front R34 GT-T Slotted Rotors used very low kms but in excellent condition and freshly machined.Price - $200
R33 Genuine Ganador Mirrors painted black ready to fit, can be painted any colour to suit your car - $450
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
