Hi guys
Two close friends of Lindo's are getting married in early November and require 3 x R34 GTRs as their wedding cars. I have offered mine, Craig has been kind enough to offer his... Would anyone else be willing to donate their car for a day? The couple said they will cover fuel costs etc.
Thanks! ;)
https://www.sau.com.au/forums/topic/286679-r34-gtr-owners/
I can piolet your car for the day? I'll give you my 32-R to drive to work that day if need be :(
Everyone deserves a drive of a 34 GTR! Haha... I've never driven a 32 GTR :)
lol weezy. good luck mate.
besides, i reckon she might sell her car before the date rolls around.
I am sad, but I kinda hope you're right... I want him to go to a good home!!!
Link's in cars FS forum if anyone's interested, 63k negotiable ;)
https://www.sau.com.au/forums/topic/286679-r34-gtr-owners/#findComment-4840714
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
