naa man i think it was a good idea to remove it
so all you did was use that t-piece and the joiner to bypass the unit, you didnt need to run new lines?
im suprised more people dont remove their ABS..
most people here seem to think that 4wd wont work for some crazy reason. i an say that everything works normal.
... so you made a car that's now technically illegal rather than fix the
problem?
Isn't this just going to cost you more money putting it
all back in the long run when you run into a RWC or defect check etc?
70 percent of 32's have a leaking abs unit - i removed mine to make the car safer id rather have brakes than an abs unit that does not hold fluid
the N1 gtr does not have abs either
Edited by DAS KAMU
