Hey guys, i was driving today and had no problems with my idle what so ever then tonight i drove off and tuned my headlights on and when i came to the traffic lights i was doing 1500rpm while sitting there, i looked to see if i was just stupid and had my foot on the accelerator but nope. I took off and then it happed at the next set of lights so i reved to 4000rpm and it droped back to the normal 700rpm.
I took off an came to a set of lights to see it was doing it again! i took off and before i came to a stop this time i stayed in 4th and when 5km before stopping and i could go under 1500rpm, down too like 500rpm but i came to a compleate stop and held the clutch in so as not too stall and it jumped up again!!!!!!!!!! (nothing mechanical is stuck if i can get under the 1500rpm while driving :S )
I got home in the garage turned my headlights off when it was stopped in there and was doing 1500rpm and soon as they went off it went to 700rpm.
Electrical problem most likely seeing as i could go to 500rpm while driving if i slowed right down in 4th.......
i dont know where to begin looking on the r33.....
https://www.sau.com.au/forums/topic/287149-weird-idle/
there are plenty of things he can do before paying someone to look at it. various things can contribute to the idle speed, especially after lift off. first of all there is the old IAC and AAC setup. also the o2 sensor can contribute to this as well. i have heard of people with dodgy o2 sensors causing similar issues. i know that in the missus pulsar though that if i am driving and pull up, sometimes the revs drop to around 1200rpm for 3 or 4 seconds and then will settle down to the normal level after that. however in your case, because it dropped after you turned the lights off, it is more than likely going to be caused by the AAC. the AAC is the Auxilary Air Control. this is designed to alter the amount of air going into the motor (mostly at idle) to stop the engine stalling when extra load is put on the engine by such things as the alternator (when the lights are turned on) or the aircondition compressor.
https://www.sau.com.au/forums/topic/287149-weird-idle/#findComment-4816089
yeah it has done this before about 2 months ago when i used headlights. Didnt do it since then and i have driven heaps with my headlights and tonight it didn't do it......
It is a brand new engine but the wiring is original 171,000km
Alternator was taken from a mates skyline with only 38,000km. i also took the engine with wiring harness and lots of bits. even the exhaust manifold with a O2 sensor on it. My sensor is old and rusty and i should have swapped it when i did my engine.
Anyway, no progress on the idle as i did stop tonight a few times and it just was normal, i knock it into neutral just before i stop and it idles at 1200rpm and then when it completely stops in neutral it idles at 700rpm so it was being normal tonight. Unlike last night staying at 1500rpm without budging.
https://www.sau.com.au/forums/topic/287149-weird-idle/#findComment-4817635
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
