hey,
anyone care to give me a brief idea of what symptoms id expect for worn synchros?
when i change mainly from 2nd to 3rd (and sometimes 1 to 2nd) i can feel contact similar to when its attempted without the clutch fully depressed. I can also force this by coasting, clutch fully depressed, and move between say second and third there is a definate point of crunch.
Sound like synchros or more like the clutch no disengaging enough?
Yeah i got no idea.... wouldnt mind attempting to having a vague idea before i take it to a mechanic and get screwed.
Cheers.
https://www.sau.com.au/forums/topic/287274-r33-gtst/
hey,
Cheers.
Is the clutch engage point near the floor or near the top of the pedal travel. If its near the floor, it could be out of adjustment and be causing the problem you are describing.
If it's mid way or near the top then this is not your problem.
Line clamp the slave cylinder flex hose and then put your put firmly on the pedal. Note if it sinks or is immediately solid.
If it is solid, the the master cylinder is going to be ok. Check the slave cylinder has minimum 12mm of travel when the clutch is depressed. If you have at least 12mm of travel and the slave pushrod is not sinking back into the cylinder, then the problem could eaither be:
A grabbing spigot
A misaligned/bent clutchplate
Worn Synchros
https://www.sau.com.au/forums/topic/287274-r33-gtst/#findComment-4817528
This is most likely gear synchros - second and third are always the first to go because they are the most commonly used and frequently abused gears. Clutch related problems typically show these symptoms in all of the gears as opposed to one or two.
Does it make the crunch sound on downshift? If so, try double clutching it to see if this gets rid of the sound. If it does then it is definitely worn synchros. The usual go with it is a gearbox recondition. Budget about $1300-1500 for the lot.
https://www.sau.com.au/forums/topic/287274-r33-gtst/#findComment-4818059
That is true but poor hydraulic pressure will actually emphasize a slightly worn synchro, even though it may not be near the end of it's life. And it is not so good to assume his synchros are at fault even though it is probably the most likely cause.
https://www.sau.com.au/forums/topic/287274-r33-gtst/#findComment-4818094
I use a little chart on my wall that says "Skyline gearbox crunching = thrashed synchros". To date it has never let me down :D
But I accept your point is plausible. Low gearbox oil can produce similar symptoms too.
https://www.sau.com.au/forums/topic/287274-r33-gtst/#findComment-4818640
I use a little chart on my wall that says "Skyline gearbox crunching = thrashed synchros". To date it has never let me down :whistling:
Down shift doesnt seem as bad but not much difference to be honest. Does the same this coasting, along clutch, in between 3 and 4th. Doesnt seem to matter what gear. I can find a spot where it grinds.
Clutch take up point is around the middle to upper end. If the car is rolling say at walking pace (or even less), it doesnt like being given first gear as easily.
Anyhow, ive got around 200kw atw now so im more than likely pushing the boundaries of the stock clutch. Change that next week. whatever can handle up to 250kw or thereabouts. and do gearbox oils aswell with something decent. f**king expensive to reco a gearbox $1500 bucks!!! oh well we'll see i guess
Cheers for the response.
https://www.sau.com.au/forums/topic/287274-r33-gtst/#findComment-4821013
aahhh try again with the below punctuation.. top effort.
Down shift doesnt seem as bad but not much difference to be honest. Does the same thing coasting along, clutch in, between 3 and 4th. Doesnt seem to matter what gear. I can find a spot where it grinds....
https://www.sau.com.au/forums/topic/287274-r33-gtst/#findComment-4821018
in my r33 4th gear does it even if im just cruising slowly through gears but i can avoid it my double clutching, also does it down shifting from 5th to 4th, i know....its fked haha but can you just get 4th reconditioned for cheaper cos were not all made of money or am i up for the whole shabam?
https://www.sau.com.au/forums/topic/287274-r33-gtst/#findComment-4828149
So it is crunching in all gears then? If this is the case it is probably a clutch issue...synchros usually give way to only one or two gears crunching. The fact you have that much travel in your clutch pedal before contact...your pressure plate may be severely worn or you have air in the hydraulic lines?
You can get just 4th gear repaired but it's not very good practice to just repair a box and put it back together with old seals and bearings. Weakens the tolerances of the gearbox and the thing will probably need to be pulled apart again in a few thousand km simply because another bearing will fail.
https://www.sau.com.au/forums/topic/287274-r33-gtst/#findComment-4828424
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
