just got back. was pretty good. we were sitting on the grass side wen one blew the tyre and 2 chunks landed near us. lol. a bloke ran up and took it. pretty funny.
love the top fuelers.
we were walkin up to buy tickets and this bloke gave us 4 cause his mates didnt rock up so we got in free too. cheerin
i went on sat night with my cousin (black widdow) and his lovley new wife jacinda. it was great watching them at night. we were at the finish line but walked up the other wnd just b4 the top dorslamer blew the tyre.
your life only truely begins after your Top Fuel cherry has been popped.
true that Paul. it was the missus first time and she shit herself. i laughed. lol. gotta love the sound and vibration. one of a kind. especially when 2 are running down perfectly together.
Edited by SLY-25T
I couldn't believe how much your eyes rattle in your head when the top fuelets go past, and the one that blew the motor at half track it was insane how you could feel the heat when your not even really close to it. I'm still buzzing and can't wait to go again
Was there too, it was great.
HAHA sure feels like its your eyes shabe but there 120Db+, they are actually vibrating the sound barrier.......sweet :P Also found out that each pipe coming out the engine release's 300kg's of pressure which was hard too believe. Ill be going again :D
my brother used to pilot a tf rail and finally an fc. for shits and giggles get someone you want to prank on, stand near one of them on a prep run (startup in the pits pre run). muhahah >: ) wish they had em in melbourne again. :P
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
