1993 JZA80 RZ Supra
Selling due to job change (back on apprentice wage) and its just simply too good to be drivin to work and back.. this was a weekend only car for 2 years. the KM's are genuine as it was bought at 98,000kms and it only just had its 100,000km service, most of them are usually wound back.
Drives like a dream, extremely quick, gets looks all day long. The transmission has been shift kitted, pretty much instant gear changes.
Would consider swaps for a ute, stagea or another import.
Currently running 18psi and making just under 320rwkw.
Turbo is capable of making much much more. (25+psi)
Handles well, great to cruise in.
Sitting at 150,***km's.
2JZ-GTE 3.0ltr
Highmount ceramic coated heat resistant manifold
HKS 50mm External Gate
ATI/Titan Harmonic Balancer
Dump pipe heat wrapped
Bosch 023 Fuel Pump
Big Greddy Front Mount Intercooler
Chrome welded piping with heat proof and antiflammable silicone
850cc Injectors
Garrett TO4Z Single Turbo - Wrapped with heat protectant
Screamer pipe
3" Straight pipe exhaust with big cannon
Pod filter - (Dose's)
Microtech ECU with Hand Controller
Do Luck Front Bar
Series 2 Lights
Greddy Spec II Boost Controller
Apexi Turbo Timer
Shift Kitted Automatic
Slotted rotors with Bendix Ultimate Race Pads
Weds 18x8 and 18x9 with Hancook Ventus K104 (255/35/18 all round)
Pioneer Deck
Splits and Tweeters
Boost Gauge mounted in air vent
Watch Alarm and Immobiliser System
Custom Vented Bonnet
Engine Breathers
Most gaskets and seals replaced
Leather Genuine Supra Seat Covers
Tuned by Brenton at Fours n More
Serviced every 4000kms religously.
Front main seal, iridum plugs, trans fluid, brake fluid, coolant all done 2000kms ago.
There is probably more that i have forgotten!
Also has 3 months rego on it
All work has been carried out at Fours n More Automotive, no expense spared.. still have receipts for around 7k+ worth of labour. Parts etc were a further 10k+
any mechanical test is welcome.. can also phone Fours n more for a brief history of the car no test pilots.
$19,000
or
swaps
Price is negotiable for cash
Located and Rego'd in Adelaide
Call or Text 0433703155 if you are interested,
Cheers.
Edited by jonohr32
https://www.sau.com.au/forums/topic/287765-to4z-black-supra-320rwkw/
was 21k but dropped to 19k.
pretty much looking for something (turbo / na / daily) with cash or ute.. stagea.. pretty much open to anything. will straight swap for the right vehicle.
I just hate driving this to construction work sites, it gets dirty pretty much instantly and i dont want to ruin it.
Edited by jonohr32
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
