post-63415-1252845580_thumb.jpgpost-63415-1252845692_thumb.jpgpost-63415-1252845438_thumb.jpgHi Guys got a set of 18" Advan racing TC2 mag wheels, wrapped in Advan Neova AD07 I think..
Mags are 8.5 on the front, and 9.5 on the back..
Tyres are 235 on the front and 265 on the back..
Bought these mags few months back from Danny at Japanese Performance centre in ozzy park.. had them on my R33 coupe for bout a week, done about 300km/s max... Tyres are like brand new, sold the skyline and now have these sittin in my shed these set me back $3k, looking for $2450 cheer Jamie
Can contact me on [email protected]
https://www.sau.com.au/forums/topic/287825-for-sale/
  • 1 month later...
Bought these mags few months back from Danny at Japanese Performance centre in ozzy park.. had them on my R33 coupe for bout a week, done about 300km/s max... Tyres are like brand new, sold the skyline and now have these sittin in my shed these set me back $3k, looking for $2250 ono cheers Jamie
https://www.sau.com.au/forums/topic/287825-for-sale/#findComment-4940066
Bought these mags few months back from Danny at Japanese Performance centre in ozzy park.. had them on my R33 coupe for bout a week, done about 300km/s max... Tyres are like brand new, sold the skyline and now have these sittin in my shed these set me back $3k, looking for $2250ono cheer Jamie
https://www.sau.com.au/forums/topic/287825-for-sale/#findComment-4940071
  • 3 weeks later...
What are the offsets?
The offset is stud off set is 114.3 and the rims width is 8.5 on the front which has I think 235 tyres and 9.5 which have 265 tyres on the back.. Hope that helps
https://www.sau.com.au/forums/topic/287825-for-sale/#findComment-4971745
Rims are 114.3 stud pattern, 18x8.5+37 on the front and 18x9.5+35 on the back
Bought these mags few months back from Danny at Japanese Performance centre in ozzy park.. had them on my R33 coupe for bout a week, done about 300km/s max... Tyres are like brand new, sold the skyline and now have these sittin in my shed these set me back $3k, looking for $2250 cheer Jamie
Can contact me via pm or at [email protected]
https://www.sau.com.au/forums/topic/287825-for-sale/#findComment-4973347
  • 3 weeks later...
  • 1 month later...
Bought these mags few months back from Danny at Japanese Performance centre in ozzy park.. had them on my R33 coupe for bout a week, done about 300km/s max... Tyres are like brand new, sold the skyline and now have these sittin in my shed these set me back $3k, sell for $2100 cheer Jamie
https://www.sau.com.au/forums/topic/287825-for-sale/#findComment-5110126
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
