Originally posted by GTR-80Y
i have also heard that to properly reset the ECU you need a proper diagnostic tool.
The proper diagnostic tool is a wire paper clip
The R33 method is to open the fuse pannel under the dash
you will see a grey connector pointing downwards, pick the two wires on their own in the plug (the ones closesed to you) turn on the ign put the paper clip in so it shorts the two wires for around two seconds (this puts the ecu in diag mode) remove paper clip.
the chk eng light on the dash will start flashing a set of codes turn the ign off & on again the ecu is now reset
benifits: no reprograming the radio or clock & no spanners sparking on the rear of the parcel shelf (killing the ecu's).
Regards DAMQIK
https://www.sau.com.au/forums/topic/2879-resestting-ecu/#findComment-50792
Regards DAMQIK
That sounds _very_ dodgey although it's probably right. I've been told that the ECU has a built in battery (button type) that even after disconnecting the battery will retain the ECU setup. So the only way is to flatten/remove that button battery or to short the ECU as described above. DAMQIK can you explain what the wires are and how it works?
https://www.sau.com.au/forums/topic/2879-resestting-ecu/#findComment-50798
Yes, one wire is an earth and the other a signal (to put the ecu in diags mode)
it dose the same as removing the passanger kick trim ,unbolting the ecu, turning it around and turning the little knob arround clockwise all the way with a fine screwdriver.
which BTW may be easyer if you are unsure about using a paper clip.
DAMQIK
https://www.sau.com.au/forums/topic/2879-resestting-ecu/#findComment-52710
im too scared to do the paper clip one as i know what will end up happening... i'll electrocute myself! :P:D
now is it the same for R32/33 or are they diff?
***EDIT
also... once u turned the nob or whatever around do u have to turn it back and then bolt it back on?
https://www.sau.com.au/forums/topic/2879-resestting-ecu/#findComment-52772
The r32 only has the knob I dont think it has a plug for a paper clip to go into.
the knob needs to be in the diag position for the whole time you need it to show fault code's
remember to turn off ign before setting the knob back into its original position.
DAMQIK
https://www.sau.com.au/forums/topic/2879-resestting-ecu/#findComment-53333
Originally posted by ex-static
Nope, I d/c'd the battery.. stomped on the brake a few times.. reconnected the battery, took her down the road until I hit the speed limiter.. 3 times :)
I thought that should do the trick :(
I was just hoping it didnt reset my safc settings.. doesnt seem to have :)
I really don't think it would have done too much.....the proper diagnostic tool is needed and after the reset there are certain driving processes it needs to help the computer 'learn'.
https://www.sau.com.au/forums/topic/2879-resestting-ecu/#findComment-53513
hey DAMQIK, can u confirm that the following diagram is correct:
|O|OO|OO|OO|
|X|XO|OO|OO|
the pins marked "X" are the ones to put the paper clip through? coz i tried doing that and couldn't put it into diagnostic mode. the bottom left marked X were free, no wires were in them. some of the others had wires in them (for the alarm i fink).
https://www.sau.com.au/forums/topic/2879-resestting-ecu/#findComment-53658
Guys! Guys!
The R33 is a little more simpler. Now, I may not be 100% on all this as I haven't done it for a while...
Okay.
Remove the kick panel on the passenger side (below the glove box). You'll reveal the computer.
Take the computer out very gentlely (its not hard, becareful of the looms and wires).
On one end of the computer you'll see a white switch, circle shape, get a small flat head screw driver.
Turn the reds on at the ignition.
turn the circlular switch oppositelock, again gently. look at the dash board, you'll see (on a series 1 gts-t) the check engine light flashing. If your getting 5 slow and 5 fast repeated flashes (it will loop) the system and its sensors are all okay.
You'll need the codes if your getting anything other then this...you can get them on the net...meggala's site might be a try there.
turn the switch back to its original postion. You'done a basica computer reading check AND reset the computer.
I would only do this if you can spend at least an hour driving on a highway so the computer can learn some good open running maps...no good doing it for 5mins......
cheers...just check on the process of turning the switch, it maybe turn switch, reds, turn back to get the result.......as long as you return it to the oringinal postion the car should be fine.
ANDREW
https://www.sau.com.au/forums/topic/2879-resestting-ecu/#findComment-53754
|O|OO|OO|OO|
|X|XO|OO|OO|
the pins marked "X" are the ones to put the paper clip through?YES if X's are towards the rear of the car
coz i tried doing that and couldn't put it into diagnostic mode. ? DID U TURN ON IGN PUT CLIP IN FOR 3 SECONDS AND THEN REMOVE CLIP?
the bottom left marked X were free, no wires were in them. ?the ones you want will have wires in them
some of the others had wires in them (for the alarm i fink) NO THERE FOR THE SEND/RECIVE FOR A DIAG COMPUTER.
To show you I pulled the plug out of its holder
The pin's of the plug you want are closest to you, on your left if you are facing toward the front of the car,
as in the picture below SORRY its not in focus.
DAMQIK
https://www.sau.com.au/forums/topic/2879-resestting-ecu/#findComment-53824
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
