These units work very well and are good value for money
NTD 3-DRIVE have 3 different settings Normal,ECO, and SPORTS. The ECO setting can be adjusted up to 5 settings and the SPORTS mode has 7 different sensativity adjustments.
This controller is easy to connect and setup, took me approx 20mins in total. There is no cutting or soldering of wires it is all plug and play.
Controller comes with Display setting unit, power harness which plugs in to your OBD diagnostic port, and pedal harness.
This controller comes with a 3A harness and is designed to suit any car on the application chart which requires that particular harness.
A full application chart can be emailed to you by request
I originaly paid $399.00 and now willing to part with it for $250.
Postage is available at buyers expense
Item location Sydney/Liverpool
If you need more info or not sure what it actually does shoot me a PM
Cheers
post-2103-1253074812_thumb.jpgpost-2103-1253074851_thumb.jpgpost-2103-1253074830_thumb.jpg
https://www.sau.com.au/forums/topic/288216-ntd-3-drive-throttle-controller/
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
