  • Replies 47
Okay starting to bug me now, have seen prank online twice in this week now, have pmed him and still to no avail.
i know its not hard to quickly sift thru your bank account and realise there is money there with my username as a reference!?
ARGH! waiting 5 mins between pm's is killing me
I've taken over Admin of ALL donations - i had a club event that had me 3hrs outta Melb from Thurs until late yesterday mate, i am fairly busy this time of year as President on the Vic Chapter.
I will take a look into it this week for you.
Can you please re PM me any information you can.
Thanks
Ash.
Donations for the time being are ON HOLD.
I need to make some changes, setup a new PayPal link and redo the way it was all being actioned.
Gimme a week or two, need to have a think about it and im busy with other tasks at the moment.
There are benefits. Increase PM space, flood control removed, PM sending control removed - pretty sure they are the things you get at present.
What about guys that donated over 2 months ago? Are you going to honour their donations???? I have PM'd you the details to no avail. Understand you are busy - but please let me know what is going to be done about this.
Cheers,
Andrew
Cheers,
Andrew
I am also in the same boat :ninja:
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
