Pair ONLY
Soft compound
65-75% tread
Will last at least another few track days.
One of the best tyres money and buy as it provides superior grip.
Worth about 450+ each tyre.
Photos here
Looking for around $400 for the pair.
Contact: 0411214643
https://www.sau.com.au/forums/topic/289022-2-x-2654017-d01j-dunlop-semi-slicks/
  • 3 weeks later...
