Hey guys, just thought it would be a bit easier to attract some of you N/A enthusiasts to help clear out my shed :(
R33 GTS4 Series 2 VCT N/A Motor rb25de 147kw, 114,000kms motor is in A1 condition, regularly serviced synthetic oils. Only pulled out for conversion. $700ono includes 4WD Sump and Front Diff, wiring loom and ecu and iridium plugs.
REASON: Took off some parts as I needed them. These include, water pump, tensioner and idle bearings, harmonic balancer, A/C and pwr/steer pump.
Can throw in a gates timing belt used 10,000kms only for $20 if purchased with motor.
R33 GTS4 Series 2 4WD Gearbox will fit stageas as well as any other running 4wd gear including GTRs. 114,000kms in good working condition, however 4th started to slightly crunch after I had oil changed too thin, needs thicker oil and will be ok.
$600ono
N/A polished Induction/Intake pipe, in excellent condition gives a nice low end induction growl. Came off R33 rb25de $150ono
Coby Extractors D12, excellent for N/A skyline, in great condition 2.5'' flange $310ono
HKS Super Drager Cat back system designed speciafically for the N/A RB25DE, in excellent condition check it out on link below.
http://www.skylinesaustralia.com/forums/R3...up-t275336.html
R33 GTR Front 5 Stud Hub Assembly good for 5stud conversions $180ono
Stagea, R32, R33 GTS4 Front swaybar $20ono
Autogauge Smoke Series Vacuum Gauge BRAND NEW $30ono
Stainless steel Cannon Muffler Angle Cut Tip - 2.5'' Inlet, 5.5'' Barrel, 4.5'' Angle cut Tip
Very good condition no dents, came off R33 $45ono
PM if interested thanks guys!
https://www.sau.com.au/forums/topic/289075-rb25de-performance-parts/
PARTS LIST UPDATE AND PRICE DROPS
R33 GTS4 Series 2 VCT N/A Motor rb25de 147kw, 114,000kms motor is in A1 condition, regularly serviced synthetic oils. Only pulled out for conversion. $650ono includes 4WD Sump and Front Diff, wiring loom and ecu and iridium plugs.
$600ono
Whiteline Rear Upper Control Arm bushes BRAND NEW. Fits r32, r33, r34, silvias, stageas, cefiro. $85ono
Gates Timing belt used 10,000kms only - $50ono
Edited by OoskylineoO
R33 GTS4 Series 2 VCT N/A Motor rb25de 147kw, 114,000kms motor is in A1 condition, regularly serviced synthetic oils. Only pulled out for conversion. $600ono take it now or it goes to my friend. Includes 4WD Sump and Front Diff, wiring loom and ecu and iridium plugs.
$500ono
R33 GTR Front 5 Stud Hub Assembly good for 5stud conversions $150ono
Very good condition no dents, came off R33 $40ono
Whiteline Rear Upper Control Arm bushes BRAND NEW. Fits r32, r33, r34, silvias, stageas, cefiro. $70ono
Gates Timing belt used 10,000kms only - $45ono fits rb25de(t), rb20 i think
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
