What do you need to know thats not on the website?
I used to be a graduate member before everyone tell me its useless unless what you're doing requires it. But I'm looking at rejoining next yr to start the bloody CPEng application.
coz im applying and preparing may application.. just want to ask if all my papers are correct and im on the right track.. is there any
interview?
What application? If its CPEng, I think there is. You will have to give a presentation as well according to the guide that gave us. Maybe check with someone who did theirs at your workplace. But if its just a normal membership, there's none. Just submit your degree and those documents they ask for and it should be enough.
pm sent
Its soon going to be worth doing your CPEng. The government are trying to pass laws where only CPEng Engineers can sign off on engineering documents etc. Basically you will be required to have it to work as an engineer soon. Queensland have already passed those laws and WA is looking to follow.
I believe in QLD whats changed is you will require CPEng to apply for RPEQ. So technically you still cant sign off drawings with CPEng, you will still need RPEQ.
RPEQ from what I understand is experience based unlike CPEng which you can just get within 3yrs after graduation with proper guidance/documentation (or thats what a lot of "graduate program" offer). I just find it stupid to pay like 600bucks a year for the freaking membership (CPEng) if you have no use for it. Most companies which require you to have CPEng will pay for it, if thats the case maybe you should considering applying for it.
Like any profession, having such accreditation will definately help in a way. Look at accountants, once they get their CPA, their wage goes up by a fair bit. I'm not saying its a guarantee increment but having accreditation will only do you good IF you need them. Same thing with higher qualifications, a fresh master grad will get the same pay as a fresh degree grad, its all experience depend (for most people anyway, not talking about the deans etc).
so is it worth the $400 when i grad mid next year? my lecturer keeps telling me to "HOLD ONTO YOUR MEMBERSHIP" blah blah. to be honest i think IEEE is better for its international recognition.
advice for a poor uni student here.
I'm an IEEE member and I don't know why really. I guess the magazines are nice to read on the loo, and it maybe looks impressive on the CV. That said, it is a useful tool for some EE areas, just not mine.
Get rid of it once you get a job. It'll only make your CV look good and thats about it. Unless your graduate program is structured for you to attain the CPEng, otherwise, I would suggest not having it once you've got a job and you dont need it. The membership fee just keeps going up every yr starting from 1st yr grad 70ish, 2nd yr 100ish 3rd... (from memory)
Never bothered wit CPEng, can't see the point in yet another bit of paper telling you that you can be an engineer, from a bunch of old dudes who don't do any real engineering anymore :)
haha true if anyone should be telling you if you can be an engineer its those of us who make your shite work :P
Yeah, we need spanner monkeys and spark monkeys to make it all work, we just get paid to come up with ideas that can never work in practice :P
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
