HI All,
Well my PC just did its auto update to Vista Service Pck 2 on Thursday night.
Now have some nice little add ons like bluetooth capability, blue ray burner and snipping tool from what i can see.
The snipping tool is very cool, its pretty much a cut and past device but i can cut anything on the screen and past it anywhere, kinda like my own pair of scissors on the PC. I know it has been done somewhere before, but there have been times when i have done a screen grab (alt+prt screen) when i have only wanted a small section of that actual screen grab, so this works great for it.
Any one else using SP2? just wanting to see if any negatives or positivves with it. Other than the new apps it all seems pretty good.
Also looked at some of the 3dmark scores and the forums and it appears that SP2 makes the scores ever so slightly less....
https://www.sau.com.au/forums/topic/289633-vista-sp2/
Well to be honest i read a couple of reviews saying that it was meant to use less resources etc, but nothing really confirmed. Other than me saying....well to be honest... no difference at all, for example, writing this with no other apps open other than coretemp and rivatuner plus 2 ie pages it is idling at 48%ram usage. CPU usage though is next to nothing at 2%
So no major resource differences, if anything more to be honest.
Vista has kind of grown on me, or is it jsut that i have put up with it for so long that anything slightly new i get over excited about?
Anyway to answer your question, wait for Windows 7. much better reviews on it so far, plus in the long run you would prob have to upgrade to it later anyway.
https://www.sau.com.au/forums/topic/289633-vista-sp2/#findComment-4849316
I've been running Vista SP2 for a while now (I think for about 2 months). I beleive it has done some improvements in the backend of windows but still not noticable.
I have to agee with you 25GTT. Vista has grown on me aswell...I've even getting use to cancel/allow message (bizzare) but I guess it's just me warming up to Windows 7 and giving that a blast
has anyone here using Windows 7 (well at least the beta)
https://www.sau.com.au/forums/topic/289633-vista-sp2/#findComment-4852162
I've gotta rebuild for 7 when i cbf'd, so next few weeks.
Heaps better than Vista from all reports of people i know running it now for 3 months or so.
Mainly in the Media Centre department, much more optimised, no crashes, hardware conflicts etc and this is all on a RC copy... so official should be very good
https://www.sau.com.au/forums/topic/289633-vista-sp2/#findComment-4853210
Running windows 7 RC on my laptop atm.
So far I'm impressed by the fact that auto update manage to find drivers for my video chip while Nvidia site couldn't get it right (mobile 9500GS).
https://www.sau.com.au/forums/topic/289633-vista-sp2/#findComment-4853286
Running a MSDN copy of Windows 7 at work for testing purposes.
So far so good - definately faster. I feel they took the good bits from Vista nd XP and put it into one package.
Installed Windows 7 on some pretty average laptops which struggled under Vista - Mobile AMD64 with 2GB RAM - Windows 7 is definately a winner.
Only issue I had with Windows 7 was video drivers not installing properly therefore no "Aero" or nice graphics - it says it is installed fine - but device manager sees the video card as a generic item - ended up having to manually install the drivers which seems to work.
But in saying this - Hopefully Windows 7 remains as fast as it is on the official build.
https://www.sau.com.au/forums/topic/289633-vista-sp2/#findComment-4853813
been runnin win7 rc since about may on my main home pc..still runnin xp3 on my old comp cause it cant handle 7 yet...
have not had 1 issue with it at all..all drivers updated instantly and has never crashed..actually had problems when i tried to load drivers from disk...so dont bother with disks now...still unhappy about no blu-ray support.. but im sure there will be decent codecs too fix this soon as its released...but seriously dont think blu-ray is worth the hassle anyways...
tried various versions of vista and was never happy...
Win7 FTW.....
https://www.sau.com.au/forums/topic/289633-vista-sp2/#findComment-4875887
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
