Today I made a major investment.
I bought a spigot bushing for a massive $8 :)
Part no. is 32202-7f401
For those not familiar with the term, the spigot bushing is a bronze sleeve bearing in the tail end of the crankshaft which carries the nose of the gearbox input shaft to provide proper alignment of the clutch disk.
Soak it in oil for a day or two before you install it. The oil penetrate the tiny holes in the bushing.
The old one is removed with a rod just a tad smaller than the inner diameter of the bushing and some ordinary grease. Fill up the hole with grease, put the rod inside the opening and tap it with a hammer a few times. The rod will press against the grease and the grease will force the bushing out. May take some harder taps if the bushing is a bit grumpy.
Lots of pins to crimp on the cables for the DTA-ECU. Only remain some heat-shrink tubing and they are all done. The photos show the sensor cables. The Power cables I finished earlier.
Have searched for a long time to find combined blinker and position lights to match the new front bumper and now I have them :rofl:
From Creatix I got a very nice oil cooler for the power steering. Perfect for demanding driving on track and drifting.
Thanks to Zef Engineering and their splendid new deal with Driftworks, the car got a massive dose of safety and an awsome upgrade with new CS2 coilovers.
A major thanks to Zef Engineering and especially to you Thomas who made this possible! :P
Coilovers installed. The front ride height is adjusted with tyre/fender in line. It will stay at this height untill the the coils have settled whereafter I will adjust them to a lovely deep level.
At the rear, the rims are in level with the fender edge.
  • 1 month later...
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
