  • Replies 48
taskforce diagonal will be meeting up before to cruise to the meet point together, why cant we :P
The meet point shall be at the Port Adelaide Police Station's carpark - cruise in together with the taskforce :(
Well i'll be there around 1pm, weather is looking to turn in the afternoon but should be a great day anyway. And Dion, if no one shows i'll head to your mates place.
lol I never made it this far by the looks of it. Blew a hole through my top radiator hose and had the windscreen covered in radiator fluid. Thank you Xtra chewies for a temp hole blocker :3some:
Was good to catch up with the few guys I did know.. pretty much dion and james. Saw vu but thought he was asleep lol
top cruise, saw a few of yous but was running around everywhere so didn't get a chance to say hi.
after this i pretty much need to get some sway bars, front guards flared a bit, rear guards fixed up and painted and then lowered some more :3some:
anyone got pics of the cruise?
Edited by SkyHi_33
Did you say SWAYBARS - yes you need swaybars, everyone should get swaybars :D
after this i pretty much need to get some sway bars, front guards flared a bit, rear guards fixed up and painted and then lowered some more :D
I have a few pics. Yeah I saw your car but Ive never met you before, I loved your rims so much I had to take a pic lol.
I know some people dont like thier plates showing so I removed them all (well the Australian ones haha), but if you particularly want your plate showing let me know :D
<snip>
Also sorry to whoever was driving behind me; I had the black R32 GTS-t /w GTR bar & wing - for spamming you out with black smoke and flames. It desperately needs a tune/remap.
had a MASSIVE hanger out the back for a good 20 seconds after we exited the top of corkscrew, look niiiiice thumbsup.gif
:3some:
Pics. Enjoy.
Had a ball, i was with the front group and got hell lost on the second leg, should have followed the directions more instead of trustin the ppl in front of me.
Ended up goin through lobathol up to lofty, good day. Bring on the next one
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
