recently i have noticed that the front windscreen has been fogging up at the bottom in the center, even in the middle of the day, but its almost a steam like fog that moves around, gets bigger n smaller n moves around a little bit but generally in the centre of the windscreen.
this also started with almost a burning smell everytime i turn on the air conditioner/heater
now today the temperature gauge was reading high and i found out there was no coolent in the radiator so i filled that up and it doesnt appear to be leaking.
the steam is still evident and the smell is still evident
it almost smells like a burning oil smell.
anyone know what could be happening or have had this problem before, im really hoping someone can guide me in the right direction here.
p.s did a search found nothing :P
i got a bad feeling your heater radiator has a leak in it...
maybe just a small leak to cause steam but no drips..
only thing i can think to test this is drive around for a little while with the radiator cap loose so the system doesnt build up pressure and see if it still does it. dont drive like this for 2 long and you will probably need to bleed the cooling system again after.
dont know if this helps but give it a shot.
yeah sounds like you have a leak somwhere in the heater box and that is causing the smell, the fog and the overheating and loss of coolant.
first thing i would be doing is disconnecting the hoses that go into the cabin from the engine bay so that you don't loose any more water and damage the engine. then find the tutorial on how to remove the heater box and have a look for signs of a leak
If i do keep losing water and just keep topping it up before it gets low i should be able to drive for a week or so yea?
i wouldnt baby it, as babying doesnt really change too much
i had a small leak in mine years ago, couple days later sitiing in peak hour morning traffic it burst and filled the cabin with steam lol was probably pretty funny to watch, but not cool for holding coolant.
really need to look at bypassing it quickly
quite easy to do, grab a set of pliers, and some steel pipe or the likes.
Disconnect the 2 pipes going into the passenger side of the firewall and then push the steel pipe into one of them and use the hose clamps that were originally used to clamp it, then connect the other pipe to the other end effectively bypassing the heater core,
I had this problem a little while ago, unfortunatly i was left with a nice wet patch in the passenger footwell!
Since bypassing the core i have no problems, and ill eventually get around to replacing it at some point, but i dont think i need the heater for the summer :whistling:
ok so found this
excellent tut on how to replace the core yourself
so i shall bypass is asap and then once ive got a free day will DIY it
heres the link for anyone who wants it, a very good read
http://www.skylinesaustralia.com/forums/Re...80#entry4864480
yeah i just felt mine 10 minutes ago, also got it.
thanks everyone for your help, this is why i <3 SAU
  • 4 months later...
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
