Currently got my gbox out of my 34 GTR to replace the shitbox clutch ($1900!!! one) that the previous owner fitted only 2 months ago. It was fitted by a total twit from Cairns who wrecked many other things too (don't know if i should name n shame, pm to find out who), and the spray of grease from the release bearing seems to have killed it.
The symptoms i had were very heavy shudder, NO ability to take off up steep hills, and very rattley at low revs. I have been told that the noisiness is a result of either the solid flywheel that replaced that dual mass not dampening the driveline noise like the factory one would, or the input shaft bearing has been worn out by the weight of the full ceramic button clutch.
Anyone have any thoughts on what this is likely to be, and whether or not the bearing can be changed without stripping the box entirely? I have conflicting reports about the ability to change it easily...
https://www.sau.com.au/forums/topic/290634-input-shaft-issues-34-r/
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
