As per topic, I have a white 1994 r32 gtr for sale.
- R33 gtr engine installed ~ 4 months ago, obviously rear main, all gearbox seals/scopot replaced.
- 90,000 kms
- Brand new exedy cushioned button clutch (Cost $1k).
- Nismo lightweight flywheel
- New tailshaft centre bearing
- Cusco adjustable arms
- Front left cv boot replaced/ Powersteering boots replaced
- Mines ecu
- 18" x 9.5" BBS LM wheels (have gutter rash)
- slight dint in rear quarter quoted around $550 to repair
I had the engine replaced after a turbo wheel destroyed the old one. Car is still not perfect and would be great for someone willing to put a little time and effort into finishing it off. Selling because I have no need for a car right now.
Price: $16800 reg/rwc dependent on sale price
https://www.sau.com.au/forums/topic/290670-1994-r32-gtr-white/
Hey mate,
Couple of questions:
What does it need for a roadworthy certificate?
Is there any surface or structural rust underneath (or anywhere else)?
Does it have standard suspension and what condition are they in?
Can you post up a couple of pictures of the engine bay, interior and (if possible) underneath the car?
Cheers,
Regarding a roadworthy certificate Im not sure it would need anything. I had a mechanic go over it around 1 month ago and spent a grand on a heap of small things (lights, ps boots/cv boots, all hicas was removed and lockbar installed, new genuine tailshaft bearing, new engine mount, service etc). Has standard suspension in good working condition. The chassis rails are in good condition and there is 1 spot of rust I know of on the LHS rail, and from memory it hasnt penetrated deep. There is barely any rust in the car at all. I just dont have the time to continue finishing the car and dont get to drive it anymore. As the interior sits there is the normal bubble on the dash and seats are in good condition with no rips.
As per any other issues. I still havnt gotten around to installing the ecu kick panel since the engine conversion and the dash panel below the steering wheel needs to be screwed back in after I removed an old turbo timer. It is a bit hesitant when cold. There is a large scratch on the front bar. I will try and get more photos tonight. The biggest issue with the car is the 4wd is transferring constant drive to the front wheels. I have had this problem before with slight inconsistency of tread sizes front to back, so I will swap the bbs wheels back on and bleed the attessa system to try rectify.
  • 4 weeks later...
Hey mate.
very interested in the car.
if you could send me a private message with your number i would like to come down and have a look.
cheers mate.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
