  • Replies 71
People staying:
Fri & Sat
Bec
Ryan
Mick
Tim
Kieran Robinson
Chris McColgan
Gary Swift
Colin Clark
Chuck us four in the same room if you can please, might be difficult considering none of us want to sleep in the same bed.
Definitely doing skittle bombs! Its the least we can do considering all the effort you go to for us.
Ahhhh Kez your going, i remember'd your name from the other night on the Supra Club cruise. Is Dom or anyone of those guys going?
Nah, but Gary (the guy in the Soarer) will be there, and his mate Colin who was riding shotgun in my car will be volunteering/watching.
Yeah i might be getting a job today so if i end up getting it ill come along, least i know some1 to talk to then, ahah. I replaced my wheels aswell lol. Got 100% 14" tyres atm :P.
Yeah i might be getting a job today so if i end up getting it ill come along, least i know some1 to talk to then, ahah. I replaced my wheels aswell lol. Got 100% 14" tyres atm :P .
Volunteer to help!
Seriously. It gets you right up close to the action, and many drivers (myself included) will be willing to let you jump in as a passenger for the afternoon runs.
Im not sure whats happening exactly, i was planning on coming just to chill out. But like if you needed my help or anything i'd be happy to do so. Just gotta find out if i got a job today at my interview hahaha. but yeah ill be all up for taking my R31 and going with whoever when we're up there.
Yeah im up for helping out. Ill come out too lol. Dont have anyone to go with though so it will be me by myself. Ummmm, not sure what i can help out with. But whatever you need i guess i can give it a go. Also, Where is DECA? When Is it?
meh what the heck im up for a night of boozing after a hard day of driving.
put me up for saturday night only pls.
must warn ppl i snore pretty bad. especially after a night of drinking lol
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
