OK I got some general maintenance done such as rocker cover gasket, timing belt, water pump etc, also radiator cleaned out.
Also added new 3" turbo back 'zaust, plus a POD filter.
That is it no other mods. It's a R33 GTST.
Now I drive it home with the widows down and thought it seemed hot but thought it was my imagination, also thought I smelled a bit of burning but dismissed it. I drove it tonight with the windows down and you can feel the heat from the foot well and fwd part of the central tunnel. Doesn't seem right. I wasn't boosting about and was driving fairly normal. Drove straight home and was worried about fire or something. I mean it feels REALLY hot.
Water temp gauge looks ok, but I notice quite a bit of activity from the oil pressure gauge; it's up and down quite a bit with the throttle. Always before it would seem to do very little, just show pressure in about the middle until the car was warmed up.
I'm thinking my engine should be a bit hotter 'cos I've probably gained 20 kw or so from the 'zaust but the heat has me worried. Can't call the shop 'till Monday so won't drive it until I check it with them.
Edited by Tony de Wonderful
Did they put the stock turbo heat shield back on?
When I got my brand new turbo back exhaust system, I felt something similar as well. Could feel excess heat when I'm stationary with windows down & I had a burnt smell as well.
If the pipes are new, the burnt smell is mostly normal. But when I 1st drove the car back that burnt smell scared the sh*t out of me as I thought my engine caught on fire & I pulled over like several times just to check the engine bay on my way home from the workshop.
After a while though, the smell gradually disappeared & I don't seem to be able to notice the heat anymore.
Edited by Mayuri Krab
When I got my brand new turbo back exhaust system, I felt something similar as well. Could feel excess heat when I'm stationary with windows down & I had a burnt smell.
After a while though, I don't seem to feel anything anymore though...
Good point. I'll ask them on Monday.
The oil pressure gauge has me worried though. I don't remember it bouncing around before.
You can check if the shield is on or not, just pop the bonnet & look for the turbo, if you can see it then the heat shield is not on. I would ask them for the old shield back & put it on, as it seem to block quite a bit of heat from the turbo coming upwards.
Also what are you seeing from your oil pressure? From what your description it seems to me like your gauge wasn't working correctly b4 & now it is...
As my oil pressure will move frequently with throttle once the engine has warmed up. Mine usually moves in the range of 2 to 6 (idle at 2 & goes up to 6 under heavy throttle).
only way to know for sure what is happening temp wise is to either get a proper temp gauge or borrow/buy a consult cable and hook it up to some software to read the exact temp. no point just guessing that it is hot if it turns out that the temp is actually fine.
edit: also you can pretty much ignore the stock water temp gauge. it will stay in the normal position up until a bit over 100 degrees when it will suddenly jump to hot.
i reckon the burning smell is normal.. new metal and exhaust putty and new gaskets etc.
and witht the guage maybe you didnt notice it before cos you wernt worried by the burning smell??
check the heat shield on the cat as well as the turbo
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
