Item: NISMO EDITION R32 GTR Skyline 90', genuine 46 878 kms on standard NISMO 320km dash, number 131 of 560
Website: here
Item Condition: VGC
Reason for Selling: Wife says it has to go, to many toys
Price and Payment Conditions: $30 000 ono
Extra Info:
This thing is absolutely stock original..except for the HKS oil filter relocator. The front bar was damaged on the boat, apart for this it is in absolute immaculate condition (front bar will be replaced before sale)
car has all the nismo leather bound books for verification.
Pictures: yes
Contact Details: 0429937651 or (07) 46 933666
https://www.sau.com.au/forums/topic/291452-nismo-edition-r32-gtr-skyline/
  • 5 months later...
Nismo steel wheel turbos
Nismo exhaust
Slightly lighter
Nismo body kit
Few extra bits and pieces
The problem with the Nismo R32 GTR's is nearly every single one is slightly different because they were custom orders. This one appears to have a 260km/h dash as mentioned earlier instead of the 320kmh. However it is definetely a Nismo one because of the serial number you can see it as BNR32-100xxx
Edited by PM-R33
"Slightly lighter" .. what makes this "Nismo Edition" lighter than a standard GTR? perhaps a missing cheese cutter in the boot?. All in all i don't see this being worth 30k. Goto japan and bring back an immaculate 1994 R32 with legitimate 50,000kms for that price with the current Yen/Aussie dollar. That is what i call rare :D
the Nismo edition had no rear wiper or motor, no sound deadening, different headlights and had the option for no A/C and no ABS. This totalled 60kg's.
The Nismo edition will always be rarer especially for collectors. These things will definitely increase in value over time.
Any way GL with the sale.
But my point being is that for small things that you can do over a period of a weekend, i can't see the 30,000 worth. Just my opinion and each person is entitled to their own.
It's the fact it's a Nismo edition and there was only a limited number of them made (regardless what is actually different about them). Makes them more of a collectable item in the long run. And it wasn't just the things I listed, there were heaps of things different about them since Nismo made so many options available.
Here's another one for sale:
http://www.skylineowners.com/forum/showthread.php?t=36451
In 50 years time I know which one would be worth more.
Edited by PM-R33
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
