http://www.rtsengineering.com.au/
There ya go Luke
And Pete im currently on the hunt for a stock one but seems very hard to find as no one is selling.
So many little things i need to get it running, but it all adds up.
  • Replies 14.2k
There ya go Luke
Thank you muchly :happy:
Arr damm. Pretty sure i'll have a 1.5K genuine nissan bill soon for everything i need.
Send me a PM of the part numbers, I'll see what I can do through my hookups at Lakeside and see if I can get it any cheaper for ya
Any idea if Z32 AFM's work with a stock computer?
What AFM's have u got in your car Luke?
you will need to have the ECU tuned for them, you can't just plug them in a drive as they have a VQ map to the factory AFM's
Edited by D_Stirls
Heaps of people selling brand newys in the FS section at decent prices, make their f**kup your gain otherwise Bosch?
*post directed to Dohmar*
Edited by Weezy
wheres the best place to get guages ?
need oil pressure gauge asap , i want one to match my greddy boost gauge but i think they are about $200 :happy:
gaugeworks
i went there to get a psi mechanical based boost gauge to fit in my car, goes to 25psi and does vaccum aswell, even uses standard globes which meant i could use the led's from 666dan. Got the mechanical oil pressure gauge too. Both are made by vdo and look quite nice, and they suit the general font and display of the r32 gauges. sample pic below. Oil pressure on the right
-D
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
    • What do the spark plugs look like after you tried to start it with everything connected?
