it is simple physics really i would draw you all a picture but should not have to explain myself. if you notice as you raise and lower a car your wheels will move in and out slightly this is the pressure i am refering to on the strut. do any of you back yard mechnics do things the correct way or just bach things out?
As I understand it the strut should neither be in tension nor compression with the car on the ground 'doing nothing'. Ergo, if you remove the bar it would make no difference to the 'sag' (if you like) between the two towers and so your (effective) alignment would be the same.
OTOH if you put your bar on with the car jacked up, the bar would be in some compression when the car is back on the ground, and yep removing the bar would change the (effective) alignment. By how much I dunno. Probably negligible.
you are correct with your first comment if there is no camber and the car is on flat ground... but i also said do not take the tyres off the ground just the weight off them, also the strut will be under slight tension or compression that is the reason for the adjustment bolt on the bar... we dont know how tight or loose his adjustment is unless you have seen the car.
i was trying to give some easy tips rather then just bash it off or get bigger muscles. i would hate to see some of the repairs (botch jobs) done on some of these guys cars.
Edited by NISMOGTT
Lol well to make sure its sharp im testing it out on your brake lines k :P
None of these suggestions have worked by the way... Gonna take it to my mechanic tomorrow, he might give it a go with the rattle gun. Turns out they are on there really tight, its ridiculous. I may have to paint it with it on the car, but thats worst case scenario because it should be able to come off
Lol never thought this question would be the cause for such a big argument. All i want is to get my strut bar off haha
Sorry for hijacking Martin
If you're still having dificulties and are NOR shoot me a PM and I'll come and help you
yea nice man they stand out red dont they ! , thats why i did mine , but yea looks good man
oh yea btw i dont even remebver u having a strut bar on ur yah34 dealy in the first place did u like all of a sudden put me in ? lol , when we where putting my heat shield in ur car i dont remeber it lol , but yea cutting disc XD , AND NO NOT ON MY BRAKE LINES :D
Edited by Yaah31
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
