Immaculate GTR with genuine low kilometers, one of the best examples of this historically significant car.
Suit collectors and enthusiasts, unmodified with the exception of Defi DIN guages replacing the standard guages above the CD player. Defi guages are obviously more precise.
I also fitted an after-market cat back exhaust though have the original. Professional installed proper alarm system.
CHERRY RED colour looks great in real life - should not be confused with the maroon colour used in later models. Great rare colour.
Driven only on sunny days on the weekend. Probably wash it more than I drive it.
Original paint, no accidents and no rust problems! Steering wheel in immaculate condition, handbrake and stick boot like new! pedals like new too. Interior condition matches low km. As does engine bay.
Gearbox is in great condition, syncros aren't worn, nor is the clutch. Bushes are tight, car feels much better to drive than most GTRs. Ready for touring.
Fastidious owner, all oils regularly replaced, including expensive gearbox and differential oils.
Low kilometers, have original auction report from Japan supporting the car's history and high auction rating.
Serviced using Motul Synthetic every 3 months, all fluids and filters routinely replaced. Many of the suspension bushes have also been replaced. Never raced.
Engine runs perfectly, idle is spot-on and has great compression. Young kilometrers and flawless service history. Will pass any test.
Late model example, 1993.
If you are after a great example of this classic car, you will definitely not be disappointed. Feel free to give me a call with any questions, worth the visit to Canberra to inspect.
Asking $21,000 which is considered by fellow enthusiasts to be a fantastic price for a GTR in original condition. Intended to own this vehicle for life, though now buying a house.
Only wish to deal with serious buyers. Located in Canberra.
Cheers,
Steve
0410378429
http://www.carsales.com.au/all-cars/privat...id=124777A953A4
Edited by neergnevets
https://www.sau.com.au/forums/topic/292879-immaculate-gtr-r32/
70,000km - supported by the condition of the car.
I did the 6hr drive to look as im looking for "immaculate" 32 but it has sill(that can be fixed ) damage from what looks to have been picked up from fork lift in case anyone wants to know before driving or flying to look ! It is tidy otherwise but depends on what you are looking for
  • 3 weeks later...
Sold for $20500 for those that are interested. GTR prices have remained rock solid for a number of years now.
that's good to hear.
I'm thinking of selling mine before the mod bug really hits me whilst it's still in fairly stock (clean too) condition.
yours was awesome though..exactly what I would have got.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
