It's a bit wierd really.
I think it's something like on at idle, then turns off at around 1100rpm, then turns back on at 4500rpm. Maybe to give better emisions at idle?? I have no idea....
That flat spot is well known, and it's the stock ECU pulling timing for some reason.
J
http://www.tomei-p.co.jp/_2003web-catalogu...haft-specs.html 4500rpm is where the NVCS turns off.
How is your fuel? 4-5k is peak torque. I had troubles with mine, as AFM had reached max voltage, and I was using stock fuel pump which just wasnt up to the task.
this was with only FMIC and Power FC running 12psi on stock turbo.
Good luck
that's way worse than it should be.
it should drop down around 4-4.5 and then pick right up till 7000rpm.
It's the ECU. Your correct. I think it fuels up a bit/timing and thats the falt spot.
All R33's i've seen have it.
I'll check the graph on a mates R33 with a PFC... might confirm?
What sort of management are you running?  What were your AF ratios?  have you tried disconnecting the VCT, or NVCS as nissan call it?  Plugs?  Also, what boost are you running?  if its over 12psi, you will hit fuel cut.
What mods have you done?
Just running stock automatic ECU with S-AFC, waiting for the shop to email me the A/F ratios, they said they were fairly steady, but need to see them for myself. I was only running around 9 psi. I am going to try disconnecting NVCS, although I think maybe it is not working at all sometimes and that could be the problem. Plugs are Autolite, gapped down low where everyone recommends for SR and RB.
Another one, have you cleaned the AFM?
Have you tried doing a reset on the ECU lately? If you have detonation it will retard the hell out of the timing and start to run like a dog. Perhaps it detected trouble when the SAFC was being tuned, compensated and needs to be reset (disconnect battery) then take it out for a flog so it can retune. I used to do this regularly when I was running stock ECU or it would loose power up top (but not nearly as bad as your dyno is indicating)
Sorry if it sounds like I am guessing, but I am:) gotta try all the common problems.
Justin,
looking at your dyno curve, the problem starts at 3500 RPM, not 4500 where the VCT kicks in. In fact the power starts increasing again at 4500.
Have you checked AFM voltage and injector duty cycle.
You may have hit a limit of one of these.
  • 1 month later...
the problem is the standard computer retarding the timing
I am still having the problem, I am using Techtom to monitor and it shows that timing is not being pulled. It is almost as if there is no spark where it cuts out.
And it is not leaning out either. Checked spark plugs and gapping and they are fine. Not sure where else to look.
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
