^^Agreed! West have you ever driven a Mitsubishi before?
Given that they can be imported for the same money as an early model RS-Four Stagea, but have more power, a better torque spread, are lighter, faster and are better looking, I fail to see how 'over-priced shit box' works in this situation.
Unless I was chasing big horsepower, I'd choose a Legnum over a Stagea every day of the week, and I'd even choose a manual Legnum over an Autech 260RS because they have better power in the mid-range where it's most useable as a daily driver.
I have and everybody to their own opinion. You'd have no problem with sourcing spare parts at decent prices where we're not.
Im not close minded. They look better than the Stag for sure but comparing power, economy, modifying, bang for bucks, spare parts support............its exactly another 3000GT. Not to consider there is hardly any snow left here in Aust where you'd need your AYC.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
