hey guys
i've got a garrett T3/T4 A/R .60 turbo on my rb25
and im just wondering if its laggier than what its meant to be.
STARTS coming on boost at 4500 rpm, to me this seems much laggier than it should be
everything else is more or less stock, apart from 3" exhaust, pod, boost controller etc.
thanks guys
Chester
https://www.sau.com.au/forums/topic/294073-excessive-lag/
.6 exhaust housing or front cover? why would u put an after market turbo on with a stock ecu, unless ofcourse you want to rebuild your motor in a few months time once u blow it up.
get an after market computer and get it tuned, might help it, but all depends on the size of the exh housing aswell...
https://www.sau.com.au/forums/topic/294073-excessive-lag/#findComment-4907287
.60 front cover, not sure of rear housing
i put it on because it was the turbo that came on the rb25 that i bought.
https://www.sau.com.au/forums/topic/294073-excessive-lag/#findComment-4907301
Honestly get yourself a stock turbo and put it back on. Power difference probably wont be that much different consdering everything else is stock and holding it back. You'll get good response and better midrange, 4500rpm is crap. Then save up for a proper decent turbo.
That's what i would do anyway.
Edited by PM-R33
https://www.sau.com.au/forums/topic/294073-excessive-lag/#findComment-4907388
hey guys
thanks guys
Chester
you will need an aftermarket ecu or even just an safc to start unlocking the power and helping to reduce the lag. Then you will find out you might also need a fuel pump, injectors and afm as your stock ones are maxing out
However im guessing the T3/T4 turbo is oldskool and is only plain bearing? (possible only oil cooled) therefore it will be laggy they some somethign newer which is ball bearing
Edited by Kaido_RR
https://www.sau.com.au/forums/topic/294073-excessive-lag/#findComment-4907917
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
