Zero One for ps2 From Genki,2003. This game is much like tokyo extreme racer but better.The features that makes it different from tokyo extreme racer is a testing feature that allows u to test your 0-400 and 0-1000 times while u change ur car settings, New bodykits which let u choose from frp,urethrane and dry carbon ( my r34 GTR has got the latest Veilside kit). There is a wide range of rims too (work,Hart,Advan,and others)
New cars, like the new ZED,and RX8,more stunning graphics(especially during rain/thunder).There seems to be a more wider array of cars, even european cars as well.The engine notes sound pretty real too.
The background of tokyo and other cities seem to be more realistic in this game, its hard not to chrash when u pass tokyo tower and other places.
There is also a feature that allows u to race more than one racer in the same opposition team in one battle.This is very cool.
The opening cinema scene is stunning as well,with a supra,corvette(the sound of the engine roar sends a chill to my spine),r34 GTR, Ae86,
There is more of phantasy to this game somewhat, with evil samurai castles and what not,if u play the game youll understand what im talking about.
so..are u gonna be the next Japan highway king?
p.s this game is not released in australia, mine is a japanese version cd,but its worthwhile to search for it, i havent slept for a long time playing it.I give it 5 stars, better than GT3 in my opinion. Anyone else played this great game?
https://www.sau.com.au/forums/topic/29410-zero-one-shutoku-highway-battle/
  • 1 month later...
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
