CONTACT: PM/sms 0421 864 698
All parts off R33series 2. Pick up prefered. Post available at buyers expense. All offers considered.
Apexi Cooler with piping to suit R33 & similar
Comments: sprayed black to avoid cop attention
$550
19inch Rims With Tyres
Front 8x225 Rear 8X245
COmments: Rear tires have traces of inside camber wear
$1100
King Springs
$140
Garrett 3040 AKA 3082R (600hp)-Housing is .86- ball bearring
Manifold
External gate 40mm
Dump pipe
Braided lines
$1500
Split fire coil pack
Comment: the car never misfired after i installed these
$350
Oil and Boost gauges with piller
Comment: comes with connections for boost pressure
$200
"mines" Front strut bar aluminium
Comments: used but excellent
$80
Cat back exhaust, includes punched out cat, muffler to quieten the exhaust. All 3 inch.
$150
Edited by adis
https://www.sau.com.au/forums/topic/294121-r33-aftermarket-partsmelbourne/
ill take the front strut brace. anything to indicate its a mines item? where abouts are you located? is it originally blue or sprayed?
Edited by john-e boi
Mate has exactly identical one. Colour, holes, welding all the same on his supra.
Originally blue but the paint is coming off.
If you want it, sms me thx
$550
$1100
King Springs
$140
Manifold
External gate 40mm
Dump pipe
Braided lines
$1500
$350
$200
$80 SOLDDDDD
$150
$550
$1100
King Springs
$140
Manifold
External gate 40mm
Dump pipe
Braided lines
$1500
$350
$200
$80 SOLDDDDD
$150 SOLDDDD
NEED ALL THIS GONE. FEEL FREE TO LEAVE ME YOUR OFFER!!
$550
$1100 SOLDDDDDDDDD
King Springs
$140
Manifold
External gate 40mm
Dump pipe
Braided lines
$1500
$350 SOLDDDDDDDDDDDD
$200
$80 SOLDDDDD
$150 SOLDDDD
Edited by adis
I wanna sell this sheet :( offers
$550 500
King Springs
$140 100
Manifold
External gate 40mm
Dump pipe
Braided lines
$1500 1400
$200 180
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
