Hi every body,i am new to this forum and from what i read over the past weeks i am sure some one will be able to assist me.
I am on here on behalf of my son and i am hoping you might be able to help me. He bought a skyline r33 with the rb 25det series 2 engine about 18 months ago, every thing was going fine till about 6months ago when he started to get a missfire. We found that the original coil packs were shorting out. I bought a new set of super spark coil packs and had the mechanic replace them. the car ran fine for a week when all of a sudden it started to missfire again and i thought it couldn't possibly be a ciol pack problem so this time i took to a high performace tune up specialist specilizing in skylines. After putting on the dyno and checking the entire system he found one of the new coil packs was not firing and we replaced it with a second hand nissan one and again every thing was ok. The faulty pack was replaced under warranty and we took out the second hand coil pack and replaced it with the new super spark pack. Two monthes down the road and would you believe it the same problem again, this time we took to a high performance specilist in melbourne who found 2 coil packs not firing. Had to pay for a genuine nissan coil pack just to get the car on the road, the car was once again running fine and after complaining to super spark supliers had the whole set replaced under warranty. I have now replaced all 6 coil packs again and 1 month later one of them has already faileddevil.gif
my son's car is stock standard apart from the front mount intercooler it has been checked by 3 different specialists and they have found no other problems, the coil pack loom is fine and has checked and it runs at standard boost. The thing is the problem has deffenetly been the coil packs but i realy can't see how all these coil packs can be faulty and fail in such a short time. Is there anything that could cause the coil packs to fail? His ECU is standard as far as we know and the mechanics do not seem to think it has been tampered with. Please help if you can. I can only tell you what the mechanics told me so i don't know how compitent they are as i think that there has to be something causing the coils to die, so fer it has been cylinders 1-2 and 6. I am thinking of taking to a place called "Just Jap Auto Imports". Does anyone know of a good place to take the car? I have been told that there could be an electrical problem can some one please shed some light on the subject ? I am a pensioner and can't afford paying when they don't find the fault and just tell me that the coils are faulty. I don't mind paying if they find the problem and not take the easy way out and surely we can't be so unlucky to cop all these faulty coils. I now this is a long thred for a new commer and i am sorry to be a bother but please can some one help. Thanks Paulworship.gif
https://www.sau.com.au/forums/topic/294286-skyline-r33gtst/
Hi Paul,
Just Jap ar great. Coilpacks are notorius on the 25's. Shell out (there should be a group buy on here) and get a set of splitfires. They do have the habit of all failing around the same time.
Second hand is just not worth spending money on.
Cheers,
Ken
https://www.sau.com.au/forums/topic/294286-skyline-r33gtst/#findComment-4910490
Hi every one, Thanks for your quick replies and feedback i just want to say that i will take every suggestion very seriously and hopfully find the problem. I made a mistake with name in my previous message about where i am thinking of taking the car, the proper name is "Advanced Jap Auto Imports" in tottenham vic. so please let me know what you think. As for the coil packs they were all brand new and they are the Supa Spark brand. Thanks Paul :happy:
https://www.sau.com.au/forums/topic/294286-skyline-r33gtst/#findComment-4910524
Hi Paul,
Cheers,
Ken
Thanks for you input the coil packs were brand new and the brand were Supa Spark, if i changed over to splitfires do you think they would overcome the problem? I agree that second hand would be a wast of time. Tahnks Paul
https://www.sau.com.au/forums/topic/294286-skyline-r33gtst/#findComment-4910531
Soz, didnt read that bit, you have a different problem then. Take it to a pro, I dont know anything about the Vic guys btw.
Thanks for help mate, thats what i will need to do but trying to find ther right person is as hard as finding the problem itself. lol Paul
https://www.sau.com.au/forums/topic/294286-skyline-r33gtst/#findComment-4910701
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
