  • Replies 69
hey mate. would you separate the bonnet lining from the bonnet and if so what condition is it in?
could you take a pic as i'd have to compare it to check if it would fit my gtr.
cheers. chris.
cheers. chris.
Sorry Chris, at this stage I prefer to sell the bonnet w/o separating any affiliated part(s).
hey buddy, do you know if the rear bumper would fit an R33 GTR?
Nismo_34
Honestly I'm not sure myself however, I have created a forum post to find out. It can be tracked by visiting: http://www.skylinesaustralia.com/forums/R3...er-t298869.html
Nismo_34
Update - received 2 confirmation that R33 GTST OEM rear bumper will fit onto a R33 GTR. Hope that thread has helped :)
