killer-t, how much would you charge for doing the modchip + HD swap (i'll provide HD), plus loading evox on with mame+64emu's and games, plus an on/off switch for live..
Rick[/quote
There is guy on Ebay who sells 120BG drives with about 30 games on it for about $280.
  • Replies 46
Guest KILLER-T
well i have decided that im out of xbox scene to many people are doing it driving the price way down to allmost cost price of the xecuter 2.2/2.3 chips and its not worth my time doing them anymore.I dont know what its like over east with people price cutting but here in perth its not good
Guest KILLER-T
Yep that is my problem i take the time to get good chips in xecuter 2.2 lite or pro and most people here use a cheapmod or something and palm them off for $30 installed calling them xecuters.One guy is even flashing the tsop and telling the customers he has fitted a mod chip:flamed: .So i think i will just play with my own Xbox from now on that keeps me busy enough sofar i have linux evox mxm and now playing with windows ce
do you have to flash your bios to install windows CE. Got the download somewhere but I heard that so have left it alone for the time being.
I also think its a bit dodge when u call up and ask for an executor 2.2 chip and they give u a price, but then u find out the just do the tsop flash thing
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
