  • Replies 52
Pete needs to deal with me? Aha... Funny stuff indeed little girl
-D
lol . . . Hrmm dono if i can make it up in the hills.. got coilpack problems . . . still waiting to get my spit fire :) cutting out at 3rpm lol
Hey guys... I came late and finally caught up with you's somewhere near blackwood..
I was in the white r34.. Mate pulled over to tell me something and then I stranded again ahah..
Was good for the short time I was there..
Hope 2 meet u all on the next one! :(
gee, you want a job as an investigator Sherlock?! :P
refer Post # 13
excellent attitude from a mod. thankyou for ur mature reply.
cruise was awesome, harndorf for lunch was a good idea too.
wah wah too hot. make tyres nice and sticky.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
