sellin my track car coz i want to get a street car wat i can use as a street/track .
i allso have a 32 4door for sale as well
will swap both cars for one clean jap car i would realy like a ceffy
heres some details : track car
d2 coilovers
strut braces front and rear
metal craddle bushes
nissmo 2way
rear camba airms
still a rb20 with rb20 box makin 220rwkw on 14.5 psi
kkr 460 turbo
bigger injectors and fuel reg
hybird front mount
cach can
bosh 040 fuel pump
monza racing seat
4 point harness
work vs 17x8.5 front 17x9 back with +30 all round
deepdish steering wheel
bost guage
stripped inside
has dent in back panel
there is prob hell shit that i forgot so yer thats about it.
chasing 7g for it coz thats how much i need for project .
r32 4door
far stock
hks springs
front moumt
nardi wheel
its auto but have a manny box at home
paint is f**ked
drive gud and runs gud
comes with stock wheels
lookin for around 6500 for it
call or sms me on 0431535983
Edited by dirtythree
https://www.sau.com.au/forums/topic/295348-r32-track-car-and-r32-4roor-sa/
  • 1 month later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
