I have loads of carbon on the plugs. So it seems to me that i have a lot of fuel added to mixture. Very rich mixture. But it is a bit dangerous to lean the mixture. I will try small increments adjust to the mixture and i will see how rich is the mixture on my wideband. Actualy is showing something like 9.4 on the wideband
Edited by pedro skyline
I was wondering is the latency on the injectors left at zero?
And the diferent value set on the injectors is there a reason?
Thanks
To Tune PFC properly the latency is set directly into the table on the left, it is only ever put next to the injectors (via hand controller) to get it to the tuner.
Thanks mate for your help. Very much apreciated. This fórum is realy a most with very good People and happy to help. I will logo my datalogit to my pfc and aply those numbers to the fuel injectors sheet on my pfc d-jetro. Thanks i will let you know how was it after that whith the mixture. As long as doesnt knock much and doesnt run lean i will be ok
Post up all your mods or email me [email protected] and i will see if i have a good solid base you can start with. You can buy me a beer next time im in Portugal :P
By the way i sended to you mail my mods.
I was wondering if i, using a timing light do the 15 degrees advance on the CAS sensor or do i compensate in Apexi PFC ignition avdance sheet? Thanks
if pfc hand controller is at 15degrees put timing light on coil 1 (dont use loop at rear unless you are confident of the offset) and set cas so that the timing light and hand controller read the same.
Ok mate cheers.
I am doing the injectors at the moment.
I Done 43.5 to all my injectors but the car is running rich on my wideband. I will try to sort my injectors latency cause by my maths is +0.24ms
But the car is steel running rich so probably it is a diferent latency. Cheers
On 28/06/2016 at 10:07 AM, STATUS said:
Just let me know if you received my email with my mods thanks
yeah im back friday so i will forward something through
Hi again status. I tryed the map you sended me and made some adjustments and car runs fine thanks alot. Now my exhaust manifold is cracked lol. I am looking for one more resistant then this one. And i have a problem with my ecu 2 pin temperature sensor. Car takes time to start and when start i warm up for a while and when a turn engine of for 10m the reading in the ecu is like -22 degrees wich is impossible.
I bought a new one and it does the same thing any ideas?
Thanks
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
