Driving down on Wednesday 07/01/04, scrutinaring on arrival.  Event starts Thurday :D.
Time we show why Nissans are the better choice :D!
Nice looking ride buddy.
I will also be arriving on the wednesday also for the scrutinaring of a mates car..... its not a line though.
What you entering your car in??
https://www.sau.com.au/forums/topic/29573-summernats-17/#findComment-606193
any one gunna dyno theres cos if yas are ill be there ill come say gday
im get the good job of workin up there so i get to be inches from turbo charger heaven
sr20's makin 414rwhp
l20 i think makin 515rwhp in a blue bird mad as that car btw it was runnin 30psi
and who could forget that ugly ugly vh 1338rwhp
any way should be better this year more rules so no one can cheat on the dyno
https://www.sau.com.au/forums/topic/29573-summernats-17/#findComment-606383
If anyones coming just to look and bringing their skyline, should cruise through Braddon on Friday night, it gets absolutely packed on summernats weekend, and is awesome to see cars of all sorts (big oldschool v8's, imports, showy cars etc).
Maybe even have a SAU meetup for drinks or something on Friday afternoon, then cruise out Friday night in one big precession? :D
https://www.sau.com.au/forums/topic/29573-summernats-17/#findComment-607239
Maybe even have a SAU meetup for drinks or something on Friday afternoon, then cruise out Friday night in one big precession? :)
Is that the night cruise strip in town? Were all the cars keep doin laps?
Would deffinately be interested in a SAU meet-up :).
https://www.sau.com.au/forums/topic/29573-summernats-17/#findComment-607891
  • 5 weeks later...
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
