hahaha yeah that dosent sound too bad craig :(
its on the crushing pile. Sorry! also got lifted with the fork through the windscreen, and because the roof was so weak it tore off.
Manual gearbox will be for sale now as i need a push style box not pull style.
Will sell box with flywheel clutch cross member and slave cylinder
Get in touch via PM if your intrested in buying the box or trading a push style box for it.
pm sent
You should be able to convert the box to push style, I have a 33GTR box that has been converted to push to suit my 32, Im pretty sure all they did was turn the slave cylinder around to face the other way. GTST box's might not be so simple though. but its worth looking into.
Ohh so it might be a simple conversion? Id need a GTST fork and pivot point, then make a bracket to mount the master cylinder on. Any links to further information?
Cheers man
yeah more info chad? I have an s2 33 gtr box sitting in my mechanics workshop just waiting for conversion and fitting... would love to know more
-D
-D
Is yours push style being converted to pull style?
or..
Pull being converted to push
-D
I just did a quick search and found this
This link is for DOMAR http://forums.nicoclub.com/zerothread/288581
I think the part where the pivot ball is mounted was removed from my 32 box and put in the 33 box which makes that part of the job easy. Then its just a matter of turning the slave cylinder around.
I'll see if i can find any info for GTST box's
or..
I got an 89 GTR which is a push, the 33 s2 gtr box is a pull. Want to convert pull to push.....
-D
Cheers man
I did a bit of a search but couldn't find any good info. Maybe try posting something in this section http://www.skylinesaustralia.com/forums/in...mp;s=&f=146 and see if anyone can help you out.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
