i am selling...
ESP LTD Deluxe H-1001 (see thru purple)
75 watt Randall RX75R Amplifier with Foot Pedal (on wheels)
Intelli Chromatic Guitar Tuner (best you can get)
Black Guitar Stand
CNB Hardcase (with opening pocket)
Purple Dimarzio Guitar Lead (High Quality)
Black Hotline Lead
and a Checkered Guitar Strap
I bought the guitar brand new in july this year, used it on stage like 3 times other then that ive just socially played it at home, id say ive probably played it about 30 times in the last 4 months since it was brand new.. my friend owns a music shop and gave me a good deal i managed to get the guitar reduced to $1900 from $2200, the reason im selling it is because my band broke up and i need cash.
SPECS.
Set-Thru, 25.5" Scale, Mahogany Body, Flamed Maple Top, Maple Neck, Rosewood Fingerboard, 42mm Earvana Compensated Nut, Thin U Neck Contour, 24 XJ Frets, Black Nickel Hardware, ESP Locking Tuners, Tonepros Locking TOM, Seymour Duncan Custom-5 (B)/Jazz (N) pick ups with 5-way Ultra Switch, Elixir .10 Guage Strings. i also added lock in connectors for the guitar strap for a bit of extra safety, the strap is already setup ready to go.
The Randall Amp is a 75 Watt RX75R, sounds good on pretty much any tune, i also added wheels to it for easy transportation (as i was in a band not long ago) i dont have a pic of it on me but this is the exact same amp http://www.bmusic.com.au/images/randall_rx75r.jpg (stands about knee height)
dont really need to explain anything else, everything is in fantastic working order, a great idea for a christmas present, unfortunately there is to much stuff to ship so if anyone is interested it can be picked up from my house in Wodonga, Victoria (3 hours drive from melbourne), still going to be cheaper to pick all this stuff up from me then buy just the guitar alone brand new in a melbourne store.
you can look at some pictures of the guitar here..
http://viewmorepics.myspace.com/index.cfm?...;albumId=528119
i am asking $1000 for EVERYTHING, keeping in mind i have spend well over $4000 so far on all this stuff.. and its all in mint condition.
feel free to PM me or email me [email protected]
Edited by azzafreddy
https://www.sau.com.au/forums/topic/295936-esp-ltd-deluxe-guitar-awesome-deal/
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
