  • Replies 41
How's this for a crack up - my agent in Japan went down to check some of my cars at the docks today and came back going "WTF is going on here? All these beat-up cars had big Chef stickers on them!!" :)
Team DeathWish takes the win.....in a pillarless 4 door...thats just gangsta :rolleyes:
Well done mate!
*shotgun C33 roof spoiler i may have already sold it..
Edited by Tom Monk
out of interest chef, how much is it costing them to bring them back through you? i'm going over to Japan in a few weeks to work in the ski fields, but hopefully will be over until spring matsuri, and thinking of buying a 32, and bringing it back over complete as banged up as it might get.
You so should get a workshop/yard for a wreckers aswell man - Iron Chef wreckers!
All of these banged up drift cars with parts that people would want, DO ET :mad:
I'd work for ya ;) ahahaha
  • 3 weeks later...
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
