Hi all, I'm selling my beloved GT-R to pay my mortgage ;)
Personal import, I owned this car for 3 years in Japan before importing it on my return. This car was not bought at auction but chosen after looking at a lot of GT-Rs over a 2 month period. I chose this one as it hadn't been fiddled with very much :huh:
I complianced the car Dec 2008, will be sold with RWC and rego.
The car is in excellent condition and drives beautifully. NISMO options include NISMO front bar (standard lip put back on as the NISMO one with undertray was 40mm lower), seats, shift knob, rear wing inserts. Twin pod filters, Blitz intercooler, HKS Electronic boost controller, TIEN adjustable suspension, ENKIE NT03 wheels, 18x11, new KUMHO tyres and Extreme performance clutch.
Small mark on left rear quarter from shipping (Grrrr), will buff out.
Oops, couldn't see how to edit topic.
Price $28,000, currently on carsales.com Car is in Western suburbs of Melbourne.
Contact me, Matt on 0424 183 696 AH only, or email: [email protected]
Thanks @ndrew :wave:
Edited by MattRS2000
  • 4 weeks later...
  • 3 weeks later...
wow, i might be checking this one out its definately what im looking for, but just a quick question you say it has a extreme performance clutch, whats it like? is it ok for traffic driving? only asking as honestly i havnt had much practice in a manual. i havnt driven one in a while and im really missing it.
thanks.
scott.
thanks.
scott.
Thanks for asking SHANE66, can't believe I left that out. The car has done 106,XXX km, 40,000 of those mine with no problems. I'm driving it about once a fortnight so kms creeping up slowly.
The clutch is fine, take up is smooth and progressive once it bedded in, it was tricky for the first 500km or so but it's quite easy to use now.
Cheers
Matt
just got another quick question for you. has it had a major service done with the belts changed? or not yet.
thanks.
scott.
I had a major service with belts including cam belt while doing shakken at 80,000ks. That was about 3 years ago, of course its been serviced as usual since then but the cam belt hasn't been done since.
Matt
  • 1 month later...
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
