Hi all :D
I have only just had new turbos installed and had the car tuned. It is making a solid & safe 307kW at all four wheels on a very comfortable 16PSi :(
Other mods include:
Built Engine
Big sump
Forged Pistons
Rods
HKS 272 Cams
720cc injectors
Garrrett Turbos
Power FC D Jetro
Exedy Twin Plate Clutch
Oil cooler
Tein Super Street coilovers
Turbosmart E-Boost boost controller
Trial full exhaust
18 x 10 +18 Work XD9 wheels
Z Tune colour coded bodykit
Pioneer 7.5" DVD/TV / full stereo
Nismo 320kmh dash
Body of car has done 139,XXXkms, but motor was only built approximately 3 years ago. I have had the car for a year and have done only 5,000km-ish in that time. Car has been serviced twice in that time. I am selling with my head, not my heart - it's time to start saving money for a house.
I need to sell this car so I have dropped the price from $62,000 to $57,000!
Respond in thread, PM me, or call/SMS me on 0402 345 185.
Bec
PS I will put pics up when I am at home as don't have any on this computer (feel free to put some up if you have any :) )
https://www.sau.com.au/forums/topic/296863-for-sale/
PS I am open to the idea of an S13/Onevia + cash ;)
Hi, Bec
I am a gtr man with a collection od S15s GTR33 and GTR34, RX7 RS 2 seater spirit r type A, we may be able to do a swap!! will call you
Alex 0439 818008 Melb 3195
https://www.sau.com.au/forums/topic/296863-for-sale/#findComment-4960781
Open to reasonable offers guys, I need this car gone ASAP... A beautifully built, serious GTR!
Pics and info can be found at Carsales ad:
http://www.carsales.com.au/all-cars/privat...0&silo=1011
Edited by missbecjane
https://www.sau.com.au/forums/topic/296863-for-sale/#findComment-4978351
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
