I've been stuffing round with my R33 gearbox with custom bellhousing for my SR20DET. I have a random washer though that I can't work out where it came from. Does anybody have an exploded diagram similar to the one in this post? Even the user manual with a gearbox break down would be handy.
Thanks
Yeah it is. You will need to pull off the reverse gear side. There is another one that looks the same but it has a tab sticking out the side which points towards the sandwich plate to locate it in that reverse shaft. It goes on the third shaft that slots into the housing. Make sure you put the bronze side towards the gear (away from the bearing)
Any questions, send a pic of the back side of the gearset and I'll circle where it goes
  Mase said:
Got another one for you. I couldn't find this same washer in the other R33 box I have so i'm unsure of the location for this one.
Yeah that goes in the bellhousing under the cluster shaft end bearing
