Hey all,
does any body have any pics of a 32 gtsts tail light pulled apart.. mayb even at different stages?
Are the lenses joined under neath or can they come out serperate? and the little orange indicator part also?
Does anyone have a tail light going cheap so i can wreck it?? lol
Thanks
https://www.sau.com.au/forums/topic/297512-r32-tail-lights/
Hey all,
Thanks
Yes the two red ones are, there is a joining bar at the top and bottom. The orange one can come out (clips in) once the clear is removed. All are glued in place, wish I had taken photo's of the one I pulled apart sorry.
Cheers
https://www.sau.com.au/forums/topic/297512-r32-tail-lights/#findComment-4958957
  • 9 months later...
