So its finally the time to get rid of my baby, deatils are as follows.
91 r32 gts-t
rb20det 181,000
5spd man.
metallic black (sprayed by dt panels 6monts ago)
Mods......
Full 3inch turbo back exhaust, split front/dump pipe, x force hi flow cat converter, blitz nur spec cat back.
rb25 neo turbo, running 12 psi
turbotech boost controller
front mount intercooler
adjustable cam gears
Safc2, tuned by re customs
bosch 040 fuel pump
just jap coil packs
greddy type rs bov
k&n panel filter
excedy button clutch
all the above gear makes a decent 187 rwkw
Fiberglass gtr front bar, vertex side skirts and rear bar
koni shocks and springs, circlip hieght adjustable
front and rear srtut brace
qfm a1rm brake pads, 4monts old
work euroline wheels 17x9+/-0 and 18x9+6
near new tyres front and rear
cabin is super clean
pioneer mp3 player with usb connection
jaycar front splits, jvc rear speakers
speco boost gauge
Thats all i can think of atm.
Price im looking for is $13,000 with rwc
Im negotiable on price and can remove parts in sale.
any questions pm me here or call 0425 759 644 any time
Cheers
https://www.sau.com.au/forums/topic/297759-1991-r32-gts-t/
I most probably have bought the car! I may be selling the wheel and tires tho... will let u know when i get the car in my possesion and anyone interested in them i will talk to then.
not until you put a deposit on it ya kent.. :)
https://www.sau.com.au/forums/topic/297759-1991-r32-gts-t/#findComment-4970454
not until you put a deposit on it ya kent.. :blink:
hahah! as soon as he pulls together the rest of the parts ill be out ther putting my money down and taking some of the spare shit on my POS...
https://www.sau.com.au/forums/topic/297759-1991-r32-gts-t/#findComment-4971154
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
