Hi Guys, currently I've organise a HID and Power LED group buy!! Group buy Starts today and will end on the 31st December.
  • 7000K available
  • SUPER SLIM BLACK BALLAST
  • Slim and Black Ballast for easy install and hide away in the engine bay
  • Every HID kit will Come with FREE pair of ENON Power LED
HID first introduced on luxury cars. After HID conversion kits had come to the market, it made HID system continued to grow in popularity. Because of high quality at an affordable price, the enon HID kit is simply the most competitive in the market. For our enon HID package, it uses high quality Xenon bulbs and ballasts. It is very easy install for your specific vehicle applications. So why don't you convert to HID now?
SAU menber price
$179 for all single beam kit
$219 for H4 Hi/ LO beam kit
Super white Power LED
$12.5 each pair OR $20 for 2 pair
all with 4 x Power LED on top of each little bulb
SUPER WHITE Power LED below
Edited by sunline08
https://www.sau.com.au/forums/topic/297776-new-enon-super-slim-hid-power-led/
As you have missed several key information items...
When you are ready to create a thread inline with forum rules which can be found here:
http://www.skylinesaustralia.com/forums/Th...Gro-t81129.html
Please repost your thread will the FULL information.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
