Hey guys I was just wondering if anyone could help me out. I am just wondering what I should set my HKS adjustable exhaust cam gear to? Im hoping for about 360kw. I will be running BP 98 ultimate. Any help will be appreciated :) Its an rb25/30
List of mods:
Stainless exhaust manifold from JPC
Dahtone Racing plenum
2.5" intercooler piping
78mm FMIC
Apexi Pod filter
Garrett GT35R 0.82
PSR 48mm wastegate
3" Exhaust
3" High flow cat
Walbro intank/lift pump
3L Surge tank
Bosch 044 external pump
Sard 850cc injectors
Nismo FPR
Block decked and bored 20thou
Wiseco Ceramic Coated reverse dish pistons
Shotpeened and Nitrated stock rods
Balanced and blueprinted
Head shaved slightly
Block O-ringed
Copper head gasket
ARP head studs
Tomei Poncams 256deg 8.5mm lift (Type a)
Stiffer valve springs
NPC 5 puk Twin Plate clutch
Red Stuff EBC brake pads
Splitfire Coil packs
Microtech LT12S
Greddy Profec B Spec II EBC
Apexi Turbo Timer
Edited by Lukas 33
https://www.sau.com.au/forums/topic/298093-exhaust-cam-gear/
every car is different. needs to be done on a dyno for best results. my engine made the most power in 0, any change and it lost power.
Yeh I thought it needed to be done on the dyno. I spoke to one of the mechanics and all he said was "we need to know the specs of the cams before we change the cam gear". This confused me a little. Hopefully they wont try and charge me an arm and a leg for the dam tune. They said it will take up to 7 hours @ 140 an hour. Does this sound about right?
7hours to tune a microtech - WOW!!!
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
