I notice from the boost vs rpm plot I received from my dyno tune that the boost gradually falls off from about 10.5psi down to 8.5psi at redline. I am using the Powerdigger Hybrid EBC. This took me by surprise, because I've never noticed this falloff on the factory boost gauge.
Is it correct that the factory ECU creates the boost level signal from the airflow meter signal? If so, could the falloff be due to a non linearity in the conversion of airflow to boost pressure? It just seems to me that the EBC might be doing it's job as best it can, using the boost level signal from the ECU, and that the only way to fix this would be to install a MAP sensor. (although I have no idea whether the Hybrid EBC could directly make use of a MAP sensor).
Greg.
Could be that the stock wastegate actuator isnt strong enough to hold that amount of boost.
I had a similar problem, I changed the wastegate actuator for a garret adjustable item. Now it holds boost right to redline.
Adam
The EBC's solenoid fits in *series* with the pressure line to the wastegate actuator, right? (i.e, it's not a bleed type solenoid) This means that when the solenoid is in the closed position (blocking all pressure from reaching the wastegate actuator), the wastegate would have no pressure on it, and the boost would rise to whatever the wastegate would allow. Do you mean the actual wastegate actuator, or the wastegate itself?
Greg.
Powerdigger are telling me the car *does* have a seperate boost sensor - i.e - seperate to the airflow meter. Now I'm confused!
Greg.
IIRC the stock boost gauge takes its reading off the back of the inlet manifold. AFM does not read boost pressure.
Greg.
A combination really. The stock wastegate actuators are sometimes not strong enough to hold the wastegate shut, so the wastegate opens more and boost drops off.
Adam
Adam
Ok, thanks. I do know that if I crank up the EBC's boost setting, the boost skyrockets (to the point of inducing a fuel cut), so if the problem is with the wastegate actuator, it must be a problem that only exhibits itself after being on boost for a relatively long time, because it is definitely strong enough for a short burst.
Greg.
Skylines certainly do have a MAP sensor, it's used to provide the fuel cut if you overboost the motor. The AFM is used for fuelling though.
Sometimes the turbo can't flow the extra boost at high rpm. When you crank it up and hit boost cut, is it still holding the higher boost near redline? Or did you only test at ~3k RPM... my turbo will hit 15psi in the midrange but drops back to 10-11psi by redline, using a bleed valve.
Yes, it is the stock turbo, but I do have a dump & 3" exhaust.
Thanks,
Greg.
For what it's worth, here's my dyno plot - looks like I slightly exaggerated the boost dropoff - it only drops to about 9.5psi, not 8.5psi as I said earlier. Is this small dropoff normal/expected with my setup? (air filter is a K&N panel by the way)
Greg.
Ok, thanks for the info. I called a performance workshop and they too said that the standard turbo may have trouble flowing 10.5psi at high revs, although if the boost is set to, say, 15psi, it will drop to about 10psi at high revs - this agrees with your observsations.
I certainly did not test the high boost to redline - as soon as I heard the engine splutter, I pulled back. (I didn't even know about fuel cut overboost protection when I did this little test - I thought I may have blown my engine and was very relieved. I had assumed that the workshop would probably have calibrated my EBC such that it was not possible to crank the boost up so high - boy was I wrong!)
Greg.
p.s I can't seem to figure out how to get the attachment to upload - sorry.
Powerdigger helped me find the MAP sensor - it's located behind the driver's side top suspension mount, just in front of the firewall. I can clearly see the hose going to the manifold. I can also see a seperate wire spliced in to the cable that runs in to the cabin - this must be the pressure signal for the EBC. (the Powerdigger Hybrid EBC has an open loop mode - I thought *perhaps* my EBC had been wired for open loop mode, but fortunately that's not the case, unless of course there's a fault in the cabling). If I do decide to monitor this boost signal, it's going to be fairly easy to access it. I'm probably not going to bother though, because it seems that the slight boost falloff I'm experiencing is probably entirely normal.
Greg.
Hmm interesting. I would have thought a MAP sensor would be better but I guess if a hose pops off the MAF sensor method will still stop the turbo from overspinning..
I guess it follows then that if you increase airflow (intake exhaust and head/cam work) then the stock ECU will stop the fun at lower boost levels because you've got more flow. So the 'boost cut' will be limiting your total power output rather than boost per se...
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
